I charged the phone.
At one point, switch off the power, time passes ...
Later, wanted to see the time - does not respond to buttons.
I reconnect the battery, try to restart the phone.
It shows a red LED and nothing else.
seus does not update the phone.
what are the solutions to the problem?
upd
after my actions
now it shows SE Logo, but xrecovery is not loading
Hi Adsky, try press and hold HOME button together with ON/OFF button till it vibrates and bootup.
phone isn't answer on home with power
it try to boot with back+power... if power cord are connected
Remove battery, re-insert after awhile, then try again (HOME with ON/OFF).
i tried already to manipulate with battery
Phone hangs up during the show's logo se
the possibility of breakage of the charge sensor?
Is the LED light up when you charge the phone?
LED is not light
when i try to update firmware - LED is green
Plug USB cable to PC/Laptop, hold the back button (don't let go) and plug the the other end of USB cable to phone. Keep holding the back button till red LED starts blinking. Hopefully it will blink until phone switches on.
