Hi guys,
New to X 10
My wife gave me her x10 and I am trying to clear her stuff off the phone and set up mine .
have searched the forum topics and cant find a solution.
I am not really sure how far i have to go back and what i have to clear . but to start with I can't get the gmail to work because it has her email address and doesnt provide a set new account option etc.
I have been through the manage applications and cleared the data in everything to do with gmail or email but still when i click on gmail from app bar it shows her account.
Any advice would be really appreciated
Dave
My main reason for you to do a software repair to wipe out the phone memory is that you have JUST GOT this phone. Most likely you have no idea whether it has the latest update. No point after doing a factory date reset plus personal settings/configuration, adding contacts .... etc, later to discover that phone is not having the latest update. UNLESS you enjoy doing all those tedious stuff (serve as practice? :smileymischief:) all over again AND there is also some risk that you might lose some stuff during the backup and restore process. Anyway, it's your decision.
Don't worry, Gingerbread won't be released so soon, therefore you won't lose timescape and camera functions.
Have fun with your 'new' toy!
You can do a software repair using either PC Companion or SE Update Service. Download any one of them from this link, http://www.sonyericsson.com/cws/support/phones/topic/updateyourproductsoftware/xperiax10?cc=gb&lc=en
This will wipe out all phone data, I assume that you do need any backup.
By the way, what did you give her in exchange? :smileymischief:
go to settings ----- > Privacy Settings ----- > Factory data reset.
which wipes all the data and user data in the phone....
Thanks Heaps
I will give it a try
Re what di I have to give my wife for the x 10 ...Nothing yet ...I know Its like those interest free loans every feels fine for a while but you know at some point in the future BANG..... its comming
I choose to live in the ignorance that is Bliss
Thanks again for the tip
Thanks Heaps Mate ,
You have saved me a heap of headaches
I will give it a go
settings.................no privacy settings? have security( configur settings for security and privacy) .................choices are sim lock, passwords, drm settings No privacy settings
Followed the link ,
saw the update .. I am a bit worried ...Is this the update to ginger bread IF( I have been looking on some of the forums and there seems to be a bit of talk that worries me for example . I dont want to loose time scape, and camera functions I have now . OR is this just the tidy up of the original software
Try looking in Settings>SD Card & Phone Storage called Factory Data Reset if you are on 1.6
if you are up to date with 2.1 it is Settings>Privacy
This will reset the phone back to its factory state so will remove all apps, data and contacts, you need to make sure you have a Gmail account
for when the phone reboots, so if you dont have one go to google and set one up first
Thanks heaps
All done
just going to have a look at what apps are available .
Any suggested sites OR ant to avoid?
