hi
my phone does not restart after the latest android update?
its been nerly 12hours and all its doing is turning on then off, i cant do anything with the phone, it dosnt let me turn it on or off, i cant do nuffing.
am i ment to have a memory card in for this?
thanks
kent
Actually you can, start up PC Companion (but don't connect phone first). Anyway, here is a link to SE Update Service, http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10?cc=sg&lc=... Good luck.
Try removing battery, put it back again and reboot phone. If that did not work, do a software repair with either PC Companion or SE Udate Service. Good luck.
ive tryed that, but when i put the battery back in it does the same thing, just turns on and off. i cant get it to conect to the pc companion as phone does not turn on
kent
thank you so much!!!
kent
Welcome. Glad you have your phone working again.
