music quality
music quality
Is the music quality of w8 with other upcomming phones like live with walkman xperia ray,neo,x10 or all android SE phones has the same music effect or it differ from w8 as per the phone specification.Is the upcoming SE phones enabled equalizer presets in their SE music player.
Johan
Master
You have a EQ with presets in all Android Gingerbread phones.
If you would like an EQ in other Android phones bellow the Gingerbread version I suggest that you check on Market.
I don't think that the audio quality of playback differs that much from model to model but more due to what headphones you're using.
4 REPLIES 4
Johan
Master
you can also install a Custom ROM (it could void your warranty but you can always flashback to the original firmware)
check this links
http://talk.sonyericsson.com/message/110154#110154
http://forum.xda-developers.com/showthread.php?t=1109563
Is it appropriate for a SE personnel/staff/mods advicing to get apps from the droid market just to enhance audio quality. Its just like shouting at everyone that those apps are far better than your own. Take a look at SE W8, dubbed the first droid WALKMAN, are those apps better than WALKMAN ITSELF? What a crap:(
