Lost favourite default ringtones after upgrading to 4.0.A.2.368
Made mistake of upgrading build as advised only to find all my ringtone and notification settings have changed and when i tried to change ringtone back to original its not there anymore, only have 12 ringtones. Have never downloaded any and one i want was standard on phone when i bought it. How do i get them back......Help Please!!!!!  Also wireless keeps dropping off now as less reception...
Uliwooly
you need to go here
http://www.droid-life.com/2011/04/05/xperia-play-system-dump-available-for-download-wallpapers-ringt...
and download the ringtones and alarms and transfer them to your SD card
5 REPLIES 5
You could have a look at this link, there is a system repository of the Xperia Play part of which is ringtone/notifications.  The other alternative if you know the name of the ringtone is have a look at https://market.android.com/details?id=net.zedge.android&feature=search_result Zedge, which has many thousands of ringtones and I know (cos I helped someone else) it has some of the ones that went missing in the update!
Uliwooly
you need to go here
Thanks for the help but hadn't got clue what ringtone was called and couldn't find it there..appreciate it though
Nice one, chuffed to bits i got my ringtone back..much appreciated!
Uliwooly
no problem
