is it possible to connect a portable hard disk to Arc?
Balakrishnan
Is it possible to connect a portable hard disk to Arc? If not, why cant SE can think about this? Pls try to do this it will be very usefull for all Xperians....:smileycool:
slimshaddy
Hero
yes its possible but i dont know how Smiling_Face_with_open_mouth_&_closed_Eyes :smileygrin:
i just saw this video..
6 REPLIES 6
It may be possible through the Live Dock accessory.
According to the website description, it says it can connect USB devices
http://www.sonyericsson.com/cws/products/accessories?cc=au&lc=en
Balakrishnan
Thanks for the reply (both). In some other brand phones it is posible to connect the pen drive or hard disk directly by using data cables.. i think its possible to connect ? Do you? And Also SE ....???
You are welcome.  I have not tried. But it would be good if it was possible. Slightly_smiling_Face
slimshaddy
Hero
Balakrishnan
Yes yes yes......
Thanks a lot. I will try this then inform to you regarding success or .......... oh no .... we canot find the word failure in SE...... always success!!!!:smileyhappy:
this is so cool
