When the phone is turned on and you press the power/lock key, I'm not sure if I'm using the right word but, it goes into sleep mode.
From that, how do you properly turn it on? Do you use the power/lock key again? The menu key? The home key? The back key?
I see a lot of videos in YouTube showing people turning it back on with the power/lock key. Is this right? I just want to make sure.
One more thing, if I have been turning it on the wrong way, does that put my phone at risk?
Thank you.
as you can see on page 9
http://www.sonyericsson.com/cws/download/1/890/089/1296821481/E15i__UG_EN_1245-0640_2.pdf
screen lock
to activate the screen press menu or power button
screen lock
if you need more info you could always check here
http://www.sonyericsson.com/cws/support/phones/topic/android21/xperiax8?cc=za&lc=en
try the simulator
uliwooly, thank you very much! That link really helped a lot! You are so awesome.
no problem, If you have any more questions let me know
