my edit icons beside the home menu is missing... how am i supposed to move icons? before this i have a problem in missing widget when i updated the "youtube" then i clear the data in home launcher, i think, but after that i cant find it.
its a limitation..
if u have selected any other "arrange apps icons " u wont get the option of moving..
thanks
thanks
