I want to know if or how can i see the time that i have talked totally or in a month or something like that.?? Thank you!!!!
if you use this 2
AContact Advanced Call log
https://market.android.com/details?id=com.yang.android.ansta
and then I use this
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
SMS backup+ to backup my sms/mms/call log to my gmail, just in case I need to double check something
Thank you very very much !!!!!!!!!!!!
Does anyone know what kind useless running program?
I'm afraid of stopping some important task..
thanks
you should not stop anything..
even if you do so they will restart again..and will deplete more battery..
so best option is to let them running
hmm
nice 1..
i just concern about my RAM..
in case i play game that use a lot of RAM..
since my phone RAM is not huge..
hmm ok..
i use xperia arc...
and i force closes these programmes..
and yes you are doin thsi on your own will..
i will not be responsible for anything
ok..
but some of the above processes starts again
u can stop them by goin to settings > applications > manage applications > running services
