Downloading video off a W980
Hi
I have a video on my W980 which I've been trying to download but I keep being told the video is too big - and do I want to trim it! I've tried using bluetooth to transfer it, emailing it, sending it via live! Studio but they all fail - either because the file is too big, or I timeout.
Does anyone know if there is a cable I can buy where I can simply connect the phone to one of my USB ports?
Thanks in advance
5 REPLIES 5
Dr_Chris
Champion
Yes, just get a USB cable from Amazon or other retailer and transfer the video to your PC by File transfer either directly to a folder or to Media Go.
can't find one on Amazon that will fit the funny power connector on the phone - and can't find anything on the Sony Ericcson site either.
Perfect. Thank you.
Dr_Chris
Champion
No worries!
