download problem
HPSH
download problem
Apps can't be downloaded due to an error. (941) . Or. ( there is insufficient space on the device) although my SD memory is empty. So what should I do for that?
Uliwooly
You will have to uninstall some apps so you can free up some internal storage
6 REPLIES 6
Uliwooly
HPSH
ok but could i download some apps on the SD card only ?
Uliwooly
you can not
HPSH
ok thanks alot :smileysmileythumbsup:
Uliwooly
Anytime
knock
I cannot download WhatsUp
