Dear Friends,
I just bought a new Sony XPERIA Mini Pro SK17I. But I found major confusion compared to Symbian. Could you please guide me on below points
1. How to deactivate the threaded message view. If it is not possible in standard then is there any another application which I can use
2. How to create group Contacts? If not in standard please let me know any available application which suffice the requirement
3. How to send the group SMS? If not in standard please let me know any available application which suffice the requirement
4. How to maintain the default mobile number / SMS sending number for my contact which has multiple mobile numbers?
5. I dont want to synchronize my contact / Calendar with Sony or gmail. Is there any way I can synchronize only on Outlook in my Laptop and edit it
I need to ask these question but these are the normally used in Symbian OS and I am so confused with Android
Thanks & Regards
Rahul
Dear Slimshaddy,
Thanks for your reply
I checked with Handcent SMS but it is showing the same threaded view. I need the standard / Old sms view used in Symbian
For maintaining the default contact i tried to follow the procedure as said above but failed to do so. Could you please give in bried. It might be different than other OS. The new phone has Gingerbread.
Can I transfer the old SMS available in Symbian OS to new Phone as they are more than 2000 SMS
Awaiting for positive reply
Thanks & Regards
Rahul Mirashi
m afraid i dont know any such application..
but try this..i dont know what type of view it has..check urself
https://market.android.com/details?id=com.jb.gosms&feature=search_result
i 2 was using symbian b4 but u have to get over it
i loved some of the features of my nokia n95 but my arc cant provide me with some things so
i dont care bout them..
mine's gingerbread to..and there shud be..
go to contacts..tap on any contact;s image or the default head..
note: not tap on the name but on the image..
options will pop out,,select the green phone..and there u must see an option "remeber my selection"
for transfering from old info use this link..u have to be logged in 1st to open the link..
make this thread as answered..
click on correct answer..
hi rahul , can u give us the reviews of this new phone as its quite new in market , especially about the battery life
from where did u bought it ??
is it officialy launched in india ?>?
just asking..
