CHECK IN ON FACEBOOk
I'm having trouble checking in on facebook on my mini pro, I tried it on the icon on my homescreen and via the internet on my phone, I have updeated the phone and facebook but still the same the loading thing just goes around and then I get sorry cant add place at this time. Has anyone else had this problem or could there be a fault on my phone?
Thanks for any advice.
Uliwooly
are you using the Facebook app or the browser or are you adding the account to Settings->account & settings?
7 REPLIES 7
Uliwooly
I've tried it on both the app and the browser, havent added it on settings
Uliwooly
this is quite odd, but when you type your password make sure its the correct one, and try to connect using wi-fi if it work with wi-fi there might be an issue with your network.
I'm getting the same problem on wifi to
Uliwooly
it might be the password, make sure you enter the correct password.
Talked to vodaphone and problem sorted had to turn on use wirless networks in location and security and it works now. Thanks for you help
Uliwooly
anytime
