Web and everything is working, but no youtube (not playing the video, it stays black, no error message). However it does work over 3G!
I set internet and streaming to allow local connection.
youtube app settings: trusted and standard internet
Also tried "repair" from PC Companion Software and various other suggestions from similar threads like set "connect with" to other providers.
Opera mini doesn't work either, not loading the video.
Is it possible, that my win7 PC or router settings are responsible?
I'm not able to eliminate this possibility by trying other PC/router at the moment.
Can someone confirm that youtube is working on his/her cedar using usb connection?
Thanks in advance for any advice.
This may be an issue with your router settings. In order for Youtube to stream a video correctly whilst using this type of connection, you would need to ensure RTSP (Real Time Streaming Protocol) is enabled in your router settings.
If you are unsure how to enable this setting, I'd recommend contacting your router manufacturer directly.
