Cedar theme compatability
i have a cedar that has theme version 4.9 and there are phones such as ELM,Yari etc that have the same theme version.
So i want to know if the themes of these phones can work on my cedar and
the theme creator version with me is 4.16 but still there is inavailability of cedar in the list
pl help me i have no themes on my cedar
Dr_Chris
Champion
http://talk.sonyericsson.com/message/69178#69178 In order to change the main menu layout according to theme, you will need the .swf file that corresponds to this theme as the file you have is the .thm file.These .swf files are only included in the phone for the pre-loaded themes but not for themes from other phone models.
This topic has been discussed extensively before, so for information on how to obtain these .swf files (these are not always available) and how to install them in the phone, use the above link to the related thread.
5 REPLIES 5
Dr_Chris
Champion
Have you tried selecting the Elm in the Themes Creator list?
no i want to lnow that if i can directly apply the themes of ELM,Hazel and Yari without creating in themes crator by selecting it from the list
and i have tried that and themes are working but everytime some elements donot get recognised if i download some themes
Dr_Chris
Champion
Which elements are not recognised?
i downloaded a theme of yari that had a diff view of the main menu icons but when i opened it in the themes creator the icons became the usual way that looked in the default themes so i want to know if i can directly apply the downloaded themes of ELM Yari and Hazel that have theme version 4.9
Dr_Chris
Champion
