cant hear anyone noone can hear me
as title says have tried rebooting and software updates is it just knackered
Dr_Chris
Champion
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/c902?cc=au&lc=en Download PC suite version 6.0 from this link, install it, open it, select phone repair under the Help tab and follow the instructions.But I would suggest you try a Master reset first.
5 REPLIES 5
Dr_Chris
Champion
Did this include a master reset and phone repair via PC suite?
no how would i do that btw its a c902 in case that matters
Dr_Chris
Champion
thank you very much works now
Dr_Chris
Champion
You're welcome.
