Can i upgrade the battery of my NEo?
my X neo has Standard battery, Li-Po 1500 mAh.... is it possible or is there a battery that has 2000mAh for this device?
everybody wants to have a long battery life ^___^
6 REPLIES 6
slimshaddy
Hero
yes you can but then also..you will be given a battery cover =D
bttery size will be big..it wont fiit in the current stock battery cover..and your neo will look horible..
but your choice..
yes you can upgrade it but not with official sony battery..
yeah it will look really bulky
slimshaddy
Hero
apc user gave some 1 a link for xperia arc and u dont want to know what it looked like =D
i just checked your link,,the same hideous cover with the x10..
yeah it's horrible
i'm glad its possible but it seems that it looks ugly :smileylaugh::smileylaugh::smileylaugh: thanks....
im not interested anyways.... i dont like how it looks...
