c905 missing contact still visible when receiving call
All,
I'm facing a weird issue. I am missing some contacts from the contact list, but when these contacts are either calling me or sending an SMS, their name appear appropriately.
Anybody know where this could come from ?
Thanks
Regis
Dr_Chris
Champion
I'm assuming that these contacts used to be on your Contacts list, so it may be that they are still on the SIM contact list as opposed to the phone contact list.If that's not the case, try deleting them from your Calls menu.
3 REPLIES 3
Dr_Chris
Champion
Hi Dr Chris,
You're exactly right - the contact was recorded in the SIM, not in the contact list.
Very helpful answer, thanks for your support again
Regis
Dr_Chris
Champion
No problem.
