assigning ringtones to contacts
Just got the arc and the instructions with it  are minimal to say the least can i designate a ringtone to an individual contact or is it just a blanket ringtone, also got the nokia x6 and i can do it with that and also it tells me who the caller is, is this function available on the arc ?
slimshaddy
Hero
yup its there..
Long press the contact in which u want to have a dift ringtone...
go to EDIT, Then Ringtone Tab..
u can choose any ringtone u want....
as far as calling name is concerned...
i dont thin arc has it..my nokia N95 sure had it..nd i loved it Dizzy_Face
but in arc its not there...
but u can dowlnload "screen reader" in which it'll read and tell u what u've opened...
i found it irritating so i dont use it, u can by goin to
"settings"
Accessibility
A pop up will occur saying to install "screen reader" click ok...
1 REPLY 1
slimshaddy
Hero
yup its there..
"settings"
Accessibility
