andriod running application
hi,
whenever i check the running services in my phone, i see a number of running applications
so i just want to know which all services those are and which one is safe to be closed.
and sorry for bad english.
gwhispererz
Champion
Hi, suggest not to touch any of those running applications/processes (unless those that are manually opened by you). Some processes automatically start up again even after killing them, just let Android OS manages it's own processes and memory.
If you really want to do it, suggest downloading a task manager from Android Market (however, my advice is 'Leave Android OS to do the work').
8 REPLIES 8
gwhispererz
Champion
thanks
and i have one more question. i am not able to access andriod market from my phone.
its pops up a message saying not able to set up a relaible connection.
can u suggest me something?
gwhispererz
Champion
A few questions before providing suggestion ....
Are you having this issue with both Wi-Fi and Mobile Network?
Is phone able to access internet? If yes, can it access your gmail account?
yes this issue is both with wifi and network options
i can access internet but not android market and gmail
gwhispererz
Champion
Let's start with the easiest way.
Remove gmail account from phone and add it again.
ok, will it help then?
i will do this once my wifi starts again, thanks for help, will let u know if any problem occurs again
gwhispererz
Champion
Fingers crossed. Slightly_smiling_Face
You can kill Timescape no problems... it is battery and CPU hungry!!!
I kill it everytime I reboot the phone!
