WiFi Issue with Xperia M4 Aqua
Vi11
Since the compilation 1.33 I can't connect my M4 to my WiFi, I have to stand like in front of the router to catch some signal and before the compilation 1.33 nothing like that happened.
4 REPLIES 4
Jonas
Master
Hi @Vi11, I'm sorry to hear about this. Slightly_frowning_Face
Have you tried connecting your phone to another Wi-Fi network? If you haven't done that and have the possibility I'd recommend doing that so we can see if the same behavior occurs on that Wi-Fi network as well.
If you have tried connecting to another Wi-Fi network and there was no change, try resetting the network settings in your phone. This will reset all your saved Wi-Fi networks, paired Bluetooth accessories and reset the settings for your mobile data connection. To do that go to Settings > Backup & reset > Network settings reset > Reset setting. When this is done, restart your device and try connecting to your Wi-Fi network again.
Do not forget to redownload the settings for mobile data, this can be done in Settings > More > Internet settings and to pair your Bluetooth accessories.
Let me know how it went!
1522
WiFi issue with Xperia M4 Aqua
Jonas
Master
Hi @1522, welcome to our community!
I'm sorry to hear about your phone.
What are the troubles you are experiencing with the Wi-Fi function on your Xperia M4 Aqua? If you could elaborate a bit on what isn't working and get back to me I will do my best to assist you!
Looking forward to your reply! Slightly_smiling_Face
Armyb
I tried but it didn't work
