Very low sound from speaker
madhav0078
Dear people,
I am facing a serious problem with Sony Xperia M2 with volume. The volume is very low from speaker.  Kindly suggest any solution pl
42 REPLIES 42
Thommo
Have you checked the volume levels in Settings then Sound then Volumes?
Jake-SonyXperia
Champion
Hi madhav0078,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You can also try booting the device in to Safemode, this will let you know if the issue is third party related or not. Use the link below to get the handset in to Safemode.
Safemode instructions
let us know how this goes.
04campbellk
I am experiencing a very similar issue. It may be down to the fact that months ago the phone got wet because since then my phone's speaker has been a bit crackly but then earlier on today, I was on a call on loud speaker and all if a sudden it drops to me barely being able to hear it. Whether I have blown the speaker with my loud music or it is something else, I don't know. Any help??
sunsky
Very bad handet it contains a dozen of issues like battery getting hot, less volume, Battery backup decrease, etc
Simplyme1
Same problem here on M2 Aqua, after Lolipop update, the sound is much lower, I think is 30% lower on whatever I use, ringtone, apps, videos, music, games.
I find it difficult to hear the phone in my pocket when someone call me or even when I receive an SMS.
I've tried everything that came up in my mind and from Google searching, nothing has solved this issue.
I hope that Sony will correct this issue in a near future update.
iridia
I bought my xperia m2 dual just 2 months ago. Everything was perfect in my opinion,and i don't even complain about camera quality.
But I'm facing the same issue as above now. And it's very disturbing.
At first,the speaker sound was good,loud and clear.
But now i barely hear notification and ringtones eventhough the volume is on max. I even can't use it as an alarm anymore as the sound was too low.
I don't know if this is caused by upgrading to lollipop, but i've tried every suggestion on google or on this forum with no result.
My last try will be tobring my xperia m2 dual to a service support,but i'm not eager to do so as they took months to fix it with unqestionable result.
Could you help me Sony?
trebor1
Voice quality is terrible and undertone on Notes, Video camera and Answeirng, boght with the phone, therefore default applications. Any similar experience? Mic test is OK more or less. No problem on normal phone conversation.
Kris77PL
Hi guys, I came here with another problem but spotted this topic and guess what: 😄 I had same problem with low sound level and I have found my own solution which does not need you to interfere with phone software or hardware... Enjoy 😉
https://www.youtube.com/watch?v=aUvZYYdW-so
shoveit
I have the same problem. When I record and check my voice is really quiet, no matter what I'm using (Notes, Messenger, Viber) On the other side I have no problems with the mic volume during calls.
