Sony Xperia M5 - Main Microphone Issue w/ Apps
TPhina
Hello,
My main microphone is not working in calls and applications, such as Instagram and Snapchat. During calls, I have to use audio speaker so that I am heard by the caller. My secondary microphone works when I film videos. My microphone works on Instagram sometimes when I uninstall and reinstall it, however the microphone stops working again. When I try to use Diagnostics, it crashes and says "Unfortunately, Support has stopped." This problem has been persisting for months, I would very much appreciate it if someone could give me a solution, as the problem is urgent.
My build version is: E5603
Android version: 6.0 Marshmellow
Build number: 30.2.A.1.21
Thank you.
3 REPLIES 3
CameronT
Champion
Hi @TPhina, welcome to the community. I am sorry to hear about this. Slightly_frowning_Face
Can you please test your device in safe mode and see if the same thing happens? It could be the third party apps causing the problem.
hushnel
Hi i've tried the safe mode but it didn't work as well. Any other diagnostics you can recommend?
Ольга31
Здравствуйте у меня проблема со звуком не работает микрофон ,хотя видео записывает и есть звук, также на звонке на громкой связи ,но нет в приложениях не аудио не в звонках.Модель Sony Xperia M5 телефону чуть больше года помогите решить проблему
Hello, I have a problem with the sound does not work the microphone, although the video is recording and there is a sound, also on the handsfree call, but there is no audio in the applications not in the calls. The Sony Xperia M5 model phone a little over a year help solve the problem
gt
