Smart Connect/Throw issue
pkw
In Smart Connect, I have created a Bluetooth event for a BT audio adapter. It pairs and works without a problem normally, but I wanted to automate in Smart Connect so that on connection it adjusts the media volume, turns wifi off and starts a player app. Now, what happens is, when I turn the adapter on, it goes into pairing mode and automatically connects to phone's BT. It then disconnects and reconnects again, this time activating Throw and triggering the actions. I tried to fix it by removing and re-adding the event and unpairing the adapter. It seems to work then (ie. on connect activating Throw straight away) byt then goes back to disconnecting first as described. Is there any way to fix this or is it a bug?
0 REPLIES 0
