Power and volume keys and camera
Refugiado95
Hola, alguien sabrá si tienen solución las teclas de volumen y encendido de mi Sony xperia m4. no funcionan nada para apagar o subir volumen no me da señal de nada al menos que presione muy pero muy fuerte.
Hello, someone will know if they have solution volume and power keys of my Sony xperia m4. nothing works to turn off or up volume does not give me signal of anything unless you press very, very hard.
gt
1 REPLY 1
Jonas
Master
Hi @Refugiado95, sorry to hear about this. Slightly_frowning_Face
Your question has been translated to English as this is an International forum.
You really should not need to press that hard on the buttons for them to work, and since this is related to the hardware in the device, there is no troubleshooting for this kind of behaviour.
I would recommend that you get in touch with your Local support team and they will arrange a repair for you, so your device can be examined by a trained technician at an authorized service centre.
I hope that helps!
