In India, Reliance Jio is launching its commercial service in coming months, It will support only Voice over LET (VoLTE) and No 2G/3G voice services. Many phones recently launched in India do support VoLTE feature and other manufacturers enabling this future with a software update. Xperia M4 Aqua has SD615 processor which inherently support VoLTE future, So please activate/enable this future with a software update.
Thanks
Hello everyone, I have received some new information regarding VoLTE in our Xperia devices and I am sorry to say that M4 Aqua is not one of the supported models according to the information I have available.
However, I have took notice regarding the interest in such a feature and have made sure to forward it internally as user feedback on your behalf, thank you for showing such interest!
This is network based, it will only work if an specific carrier/network add and enable this feature to an specific phone.
If your device supports VoLTE is dependant on your operator. I recommend that you get in touch with your operator to see if they plan to release the feature for your device.
Hi, I would like to know that does my mobile supports
VOLTE service please help me. i want to buy reliance 4g card india
ASAP
Hi @shaikh72983,
Have a look at my reply above. If your device supports VoLTE is dependant on your operator, therefore I suggest that you get in touch with them regarding that feature.
Hi pls advise if M4 Aqua dual supports VoLTE...
Model E2363
Hi @Babu75,
Please see my previous posts in this thread. You should get in touch with your operator to see if they plan to release support for this feature in your device.
It is dependant on your operator if your device will be able to utilize VoLTE, I suggest contacting them for more information @Navm.
