help manually disable the motion sensor on the phone sony m4 Aqua Dual
помогите вручную отключить датчик движения на телефоне sony m4 Aqua Dual
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Please do elaborate
Please do elaborate
