M5 camera issue!
RISOLTO
haikim
Visitatore
M5 camera issue!
Camera unstable when I press camera physical button from idie or lockscreen camera icon...sometime it will work, sometime no...hopefully next update will solve the problem...
my firmware 30.0.B.1.33
1 SOLUZIONE ACCETTATA
Soluzioni accettate
xavinux
Appassionato
Hi @haikim
Keep us update, I am at disposal for any question. f this issue persists, you can also try to boot your device into safe mode like explained in the link below:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
33 RISPOSTE 33
xavinux
Appassionato
Hi @haikim
You can try clearing the camera app data. From your Home screen:
1. Tap the Application screen icon.
2. Find and tap Settings -> Apps.
3. Swipe to the All tab.
4. Find and tap on the camera app.
5. Tap Force stop -> Clear data.
6. Restart the phone.
haikim
Visitatore
Ok, i will do it follow ur step...let see how...if problem remain, will let you know...thanks!
xavinux
Appassionato
Hi @haikim
haikim
Visitatore
Hi,  xavinux, so far my M5 camera no more lag....thanks!
xavinux
Appassionato
Hi @haikim
Glad to read that your problem was solved, enjoy your Xperia device! I'm at disposal for any question.
ykphuah
Visitatore
Hmm, what did you do exactly? Clear cache? or Boot into safe mode?
Boot into safe mode is only for diagnosis right? If you uninstalled some apps to make the camera faster, please share!
xavinux
Appassionato
Hi @ykphuah
Yes, boot into safe mode is only for diagnosis. If the issue is not present in this mode, that indicates a third party app is causing the problem. In this case exit Safe Mode and then un-install any third party apps you don't need and clear the cache/data for the apps you want to keep.
haikim
Visitatore
Hi,  until today, camera issue come back again...:smileyworried:
when u press physical camera button or from lock screen camera icon, it will hang after take even single shot...
only u need when u press after unlock the screen, camera will working....
Burst effect from M5 also lag alot....cannot catch nice photos....:smileycry:
Oluap
Visitatore
My m5 camera is not working too pls help me to fix it 😭
