M4 Ram issue, shows only 883 MB...
Ehab2
the problem is that after  I update my mobile to Marshmallow (2 month after )the phone lost 1 GB of RAM and became only 883 MB. it must be 1.8 giga I have tried every way to download SoftWare from the Sony Companion program but not solved.
Ehab2
after 1 month my 1 Giga came back . the problem is the sd card .if you use under class 10. you must replace it with class 10 . sd card make some wrong with ram storage . (both connect with motherboard)
now all i do is to pull the sd card out ,turn of the phone,put sd card again,turn on again .
maybe 1,2,3 time
now ram is 1.8
2 days the phone restart after 20 m but now all the day only 1 restart
12 REPLIES 12
profile.country.PH.title
MarlonUk1
once you update to a newer version of android. the added features would also eat up ram. so this is as expected. I suggest to uninstall uniportant apps or review background apps settings>apps
Ehab2
No way. I tried all ways to solve this problem. Companion,reset,downgrade to lollipop,rebear,. I try all ways you can imagine. The problem is it bad phone.all Xperia phone full of problems. This phone no body should have. It is useless.
Coustmour service too bad all they can do. (reset,........
You should all know that it is  Sony responsibility.
Ehab2
Aleks011
haha short storyline.. your ''another'' 1 GB of ram it's dead.. i have the same on my M4, except that mine ram got dead even when i had Lollipop 5.0.. started with restarting it self like crazy, then didn't want to boot even, i was able to receiveing SMS but cannot make phone calls, both sim cards shows no network coverage, if there was network coverage i was not reachable too just as i mentioned i was able to send and receive SMS.. the mobile data was working fine, and the wi-fi, i still keep the phone, but after the ''dead'' 1 GB of ram is slow and sluggish.. almost not usable.. and yes the restarts still happens not that often now after the ram got away.. but still happens.. oh and just to add.. this about the 883 mb ram.. was discussed long time ago.. but Sony denied to replace the motherboards.. not nice at all from their side
Uliwooly
@Aleks011
That info it's not accurate
@Ehab2
The RAM has not disappeared.
Aleks011
@uliwooly wrote:
@Aleks011
aha i see.. okay if it's not.. then where's the other 1 GB of ram.. ? i was following the forums back then pretty often, then i didn't had that problem, but now i do, so how can i return my previous ram ? as i know it by replacing the motherboard, on my own.. i'd have to pay for it, since my warranty is gone.. and even after the replacement, how can i be sure, if the motherboard would be lasting longer, or would just colapse after 3 months of using ?
Uliwooly
@Aleks011
When you replaced the motherboard, which Android flavor did you flashed?
Ehab2
maybe 1,2,3 time
now ram is 1.8
Aleks011
no you didn't get me, i still have the old faulty motherboard isn't changed what i did was updating from Lollipop up to 6.0.1 Marshmallow, but didn't change nothing except the phone isn't restarting that much now (and as i said earlier i lost the other 1 GB of ram on Lollipop version 5.0 not after upgrading to MM), but still 883 Ram.. And no, i don't have SD card inside i have 16 GB version E2363 dual-sim, back then i had like over 50 system accidents when on Lollipop, now is less
