After using an unoffical app from the playstore, to control the LED Illumination for M2 (D2303) it stopped working completely, I even reset the phone using the PC companion. It won't show up for powering the phone on, any Sony app and all unofficial apps can't get it to work again.
Bro,
Thank you so much for your comment. It really worked. I had been struggling for several months to fix this problem. But within 10 seconds I fixed it. Thanks again.
Thanks Newoo, Its worked... Hopefull many peoples around the world like you.. Thanks again
Thanks a lot!! Pressing the OFF button for around 10 seconds worked for me!
Xperia M2 D2305
in sim card slot there was a off button
pin the off button for 10 seconds
after reboot
illumination light work properly
Its a long time we are waiting for this...
Has any one has got the solution for this??
Dear friend
I think I have this problem with my xperia m2 D2305 after updating software.finally i found a solution that on memmory card and sim slot we can see a small hole with golden colour.after closing all background apps u just take a needle and press it few seconds.the phone will shutdown .then u just power on the phone go to gallery open images .now illumination bar will flash
how to solve it? Can u plz tell me how to solve this ?
