Illumination bar not working / lighting up after update 4.4.4 kitkat
Kartton
After using an unoffical app from the playstore, to control the LED Illumination for M2 (D2303)  it stopped working completely, I even reset the phone using the PC companion. It won't show up for powering the phone on, any Sony app and all unofficial apps can't get it to work again.
Tags (1)
59 REPLIES 59
kanda12
Thanks buddy its work really big thanks
Catalin1891
My Xperia M2 had the same problem! After upgraded to KitKat it stopped working!Until this morning when i saw some topics saying to push that lilittle button from where the seem is for a few seconds and then start normally with power button! Now it's working just fine when i go to albums or music player!
George09
Bro,
Thank you so much for your comment. It really worked. I had been struggling for several months to fix this problem. But within 10 seconds I fixed it. Thanks again.
Weekend
Thanks Newoo, Its worked... Hopefull many peoples around the world like you.. Thanks again
Cuisi
Thanks a lot!! Pressing the OFF button for around 10 seconds worked for me!
Xperia M2 D2305
pravezjoe
in sim card slot there was a off button
pin the off button for 10 seconds
after reboot
illumination light work properly
sadamkhan
My mobile bottom light is not working
ajinkya-
Its a long time we are waiting for this...
Has any one has got the solution for this??
Vinu3
Dear friend
I think I have this problem with my xperia m2 D2305 after updating software.finally i found a solution that on memmory card and sim slot we can see a small hole with golden colour.after closing all background apps u just take a needle and press it few seconds.the phone will shutdown .then u just power on the phone go to gallery open images .now illumination bar will flash
Mahbub247
how to solve it? Can u plz tell me how to solve this ?
