Illumination bar not working / lighting up after update 4.4.4 kitkat
Kartton
After using an unoffical app from the playstore, to control the LED Illumination for M2 (D2303)  it stopped working completely, I even reset the phone using the PC companion. It won't show up for powering the phone on, any Sony app and all unofficial apps can't get it to work again.
Tags (1)
59 REPLIES 59
Mokaa
u r my herooooooooooooooooooooooooo
evolventum
yes, method with OFF button on working phone is really work. sony support may better working, factory reset is a stupid method
sam0610
Didn't work for me
shamdzsar
Illumination bar still not work after 18.3.1.C.1.13 update Slightly_frowning_Face
Ramaraja
Thank u.!!so much...!!! After press reset button ..illumination light bar is working fine😀
sam0610
Reset didn't work..what a carp phone gonna switch to HTC or something....
S4chin
After watching this post i also checked for illumination bar of my Xperia and i am shocked Face_with_open_Mouth
My mobile illumination bar is not also working. I have done all suggested tricks but still problem persists !!!
aadeeptha
Orrrr my god it works.thank you sooo much newoo
Muchakis1
My phone is Xperia M2 D2303. When I first bought this phone and it was running android 4.3 the LED strip on the bottom was workig normally while using the Album app. Now I'm runing android 4.4.4 build number: 18.3.1.C.1.13 and the LED strip stopped working. I go trough photos in the album and it doesn't light up. I tried factory reset and I got no result. Today I did a software repair using Sony PC Companion, but that didn't help either. I also tried switching the phone off using the button under the sim card flap and then turning the phone on, again it was for nothing. If someone knows how to fix this problem I would be very thankful.
