Illumination bar not working / lighting up after update 4.4.4 kitkat
Kartton
After using an unoffical app from the playstore, to control the LED Illumination for M2 (D2303)  it stopped working completely, I even reset the phone using the PC companion. It won't show up for powering the phone on, any Sony app and all unofficial apps can't get it to work again.
Tags (1)
Kartton
Ok I'm back after some reaseach.
It seems that the update that Sony gave us for our Xperia M2s are rom bugged with the Andriod 4.4.4 KitKat Upadate.
I have flashed the 4.3 update which is Jelly Bean and the Illumiator bar working 100%.
Loaded up Albums and a pic of Konata and it blinded me with a long bright blue light.
59 REPLIES 59
Uliwooly
That seems like a hardware issue, contact your local Xperia Care
Uliwooly
erm
This has happened to me
Uliwooly
Keep us updated
prettyalex1199
Got this problem too.. What did you do to fix it?
shamdzsar
Same!!!! its not working for me too..:smileysad:
Uliwooly
@shamdzsar @prettualex1199
Contact your local Xperia care
Yudhe
Illuminating bar light is not functioning for my Xperia™ M2 Dual Phone  (D3202). I can't understand why this isn't working, please help me out regarding this
issue.My phone is currently functioning under Android KitKat 4.4.4
gaggi
Have you fixed this? I have same problem
