How to disable safe mode in Xperia Mobile
Xperianm
I have Xperia M mobile but i dont how i got safe mode in my handset but now i want to disable safe mode.. but i dont have idea about it... Please tell me how it can be possible...
Thanks
34 REPLIES 34
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
To exit safe mode you simply power off and power on your unit as normal. You can find further information about safe mode at the following FAQ-topic:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Xperianm
Thanks for reply ... I did it lot of times...but i am not able to remove the safe mode...
emilian3910
I have a problem.. I can't remove safe mode,I try to update my phone but it's steel in safe mod... And my volume down button it's not work.... Help!!!! I try evrything !!!
goelaakash90
switch off your phone, and turn it on then
emilian3910
It's not work... i switch off and turn on for 5 times... and it's steel in safe mod..... I hold volume up and power button it's not work!!! help !!
profile.country.RO.title
_alexdon_
It means volume down button is defective.
alexdon
emilian3910
It's not defected because when i update i have to press volume down button and connect usb to update and it's work !
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
emilian3910
It's steel in safe mod Slightly_frowning_Face
