Flash light not working
Qna
I reset my xperia m and also tried reinstalling software through pc companion but my problem not fixed. What should I do now?
Uliwooly
@Qna
That's good, ok, now try this:
settings > apps > camera > storage > clear data > restart the phone > test the camera again
if that doesn't work then boot in >>> safe mode  and test the camera
3 REPLIES 3
Uliwooly
@Qna
Could you test your device?
Settings > About phone > Diagnostics > Test
Oreo
Settings > Support > Tests
if it doesn't pass the test then it is a hardware issue and you will need to get it repaired by your local support
Qna
Thanks for reply fast.
In diagonastic flashlight seems to be working fine
Uliwooly
@Qna
