Mobile not starting only display xperia only
shaik1
sir
my x peria  L1 yesturday charging finish then i cherged after i want start the phone , but struck up only X PERIA
I am trying many time to re start but same problem,
i but just 6 months back
need your help
1 REPLY 1
profile.country.US.title
Qatrium
@shaik1
First, try to force restart your phone by pressing and holding the volume up and power buttons together for 7 seconds at least and see if the phone will start normally.
If this fails and you're still stuck in a boot loop, then you'll have to perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory, so you'll lose any data stored on the internal memory (SD card will not be affected).
