Help with my Charger
Mykul11
I can't plug it in. But so far I've only done it softly and I haven't done it by force or tried to jam it in there
1 REPLY 1
Uliwooly
@Mykul11
Check if there's anything in the connector; also, try a different cable, if you experience the same issue then it's time to contact your Local support
