Hello, forgot a password of the screen on my phone L2. The phone is new, used finger print as a key, then phone switched off and after i should use and code of the screen. I completely forgot it, case did once in the beginning.
The link myxperia.sonymobile.com doesnt work, computer cant find IP-address at all
Help please
Hi @Svetlana17, I'm very sorry to hear about that.
I recommend you to do a software repair using Xperia Companion to reset the phone back to factory settings.
Unfortunately you can't use Myxperia as this is discontiniued since the release of Sony Xperia XZ Premium.
Let me know how it went!
