How To: Adjust your Sony Android TV Picture Settings
5,760  Views
As TV’s have advanced throughout the years so have their uses, expanding from broadcast Television to home movies, video games, live sports, and streaming. Each of these display experiences work best with slight adjustments in your display settings.
Your Sony TV has a wide variety of settings to display your preferred content more effectively, and in this video, you’ll learn how to use them to your advantage.
Consider placing this test chart on your TV when adjusting your settings for more accuracy.
7 Comments
Maybin
Something I had not known really wonderful to take advantage of enjoying my Sony rv  thank you for the advice
Robert.CD
Excellent.  A test chart provides a consistent, static picture when adjusting the picture quality.  However it only appears to change the settings for the port where I inserted the memory stick.  How do I locate the memory stick and change the TV picture, please?
profile.country.IE.title
Mahmutlar44
Very useful information and the best part is it is so user friendly.
Even if your not happy with the outcome it is so simple to reset to default.
John-Thurman
How do you place the test chart on the TV?
Win_88
Specialist
I think it's meant to be printed on a piece of paper
toffee68.
how do you change the settings to UHD to watch sky programs ? keep getting messages saying that i need to put onto UHD but i have 2040...
SatoruGojo
@toffee68. what's the model number of your TV?
