The following instructions describe how find the web browser on your 2014 TV, as well as how to access the browser quicker the next time.
1 - Press the [HOME] button on your remote control and go to the Apps menu:
2 - Click on the "All Apps" button in the Applications screen and then scroll all the way to the end of the applications list. NOTE: There are a lot of apps, so keep scrolling across until you cannot move any further.
3 - At the end, you should see a round blue icon with the letters "WWW" written on it. Select this icon, as this is the web browser. A menu will then be displayed with the following two options "Open" or "Add to My Apps". Choose "Add to My Apps"
4 - The Web Browser is now added to you "My Apps" screen in the applications area. You can then access the browser much quicker next time around.
