tunnellvision
STR-DN1040 No output
This receiver has worked fine for 2 years.Now there is no output to the Bravia TV.I was away so I'm not sure what has happened.As I can't see the menu I can't change the settings.Is it possible to reset the unit?
Anonymous
Hi there
undefined
If this doesnt work, its likely to be a HDMI issue.  See HERE for some troubleshooting steps.
3 REPLIES 3
Anonymous
Hi there
undefined
tunnellvision
Thanks Q,I'll give that a try.
tunnellvision
Hi Quinnicus ,
 so I took your advice.It was the Handshake.I should know by now, when having problems with electrical equipment,to turn it off and turn it on again .
Thanks again.
