I've had a problem this evening when trying to watch a BluRay disc and half way through the movie the video started skipping and the audio has been making a clicking / chopping distored noise even whilst the actual soundtrack/voices are going on in the background.
BluRay - Sherlock Holmes
I am not sure if my TV may be causing this.
Its a HD-Ready Beko TV - the menu seems to support upto 1080i and video plays through this resolution however I have had to change the resolution to 720p as otherwise when trying to play blu-ray discs the entire systen freezes and the only way to reset the unit is to turn it off at the wall.
Any advice or thoughts on this would be helpful.
Thanks
Hi chriscundy,
welcome to Questions & Answers..:smileyhappy:
Do you get the same problems when playing other BluRay disc's..
