SONY AG94KTV CONNECT TO SONY HTST5000 SOUNDBAR
sotty06.
HELLO JUST BOUGHT SOUNDBAR.CANNOT GET IT  TO WORK THROUGH EARC ON BOTH.I HAVE CORRECT HDMI CABLE.IF I CONNECT OPTICAL WITH HDMI I GET IT TO OPERATE.WHAT AM I DOING WRONG.
4 REPLIES 4
Pascale_F
Moderator
Hi sotty06.,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi sotty06.,
That's very strange. What happens when you connect it? Is there no sound or does it drop out ?
Have you tried a different HDMI cable?
Cheers,
The_Black_Rose
sotty06.
HELLO USING BELKIN LEADS. THIS MAY SOUND STRANGE BUT I DISABLED NETFLIX APP ON TV. NOW SOUNDBAR CONNECTS EVERY TIME TO TV AND I GET SOUND THROUGH SOUNDBAR. BEFORE I DREADED TURNING TV AND SOUNDBAR OFF AS THEY WOULD NOT CONNECT TO EACH OTHER. ALSO HAD NETFLIX APP ON VIRGIN TVO BOX AND IT ALSO STOPPED WORKING. I HAD VIRGIN BOX CONNECTED DIRECTLY TO SOUNDBAR. THE TV WOULD NOT PLAY NETFLIX SOUND ON THIS TV. SONY AF9 4K OLED WITH Earc HDMI.SONY HTST5000 SOUNDBAR WITH Earc HDMI.CONNECTING TV/SOUNDBAR WITH Earc HDMI PORTS.
Sent from Mail for Windows 10
Vanilla_
Contributor
Hi sotty06,
I'd suggest that you connect everything directly to the TV. The sound in this case should be output directly from your sound bar. Also, Did you make sure of the "Speaker" settings on your TV? They should be set to "Audio system".
Regards,
Vanilla_
