Hi, hope you can help. I've just set up a Sony STR-DH810 Receiver and hoping to connect an MP3 player using a standard 3.5mm audio jack. Can anyone tell me how to do it? I've seen the DM Port cradle for the ipod but that's £40 and I was hoping for a cheaper alternative. Manual only refers to the DM (Digital Media) port.
Thanks,
David
Something like this
Plug the phono cables into one of the inputs and then the 3.5mm jack staight into your mp3 player. This isn't a recommendation for that specific cable or retailer etc, just a pointer to the type of cable you need
Thanks
Something like this
Thanks
Thanks, Catmambo. It's on it's way from Amazon. I'm sure it'll be fine. Much appreciated.
