RDR HXD790 Stuck in Update/Optimising?
Pagecrawler
My RDR HXD790 has been showing a message recommending Optimisation for the past few days which I was planning to do at the weekend but when I came home from work today I noticed it wasn’t recording as planned and the display was dark with “Update” just readable on it. Would this be the optimisation? Or has it got stuck on another update? As I was at work I have no idea when the problem started but the manual says optimisation could take 8 hours. So far it’s been 6 hours and nothing I haven’t heard it make any noises and I can’t turn the power on so there’s nothing on screen It usually switches on for updates at 10.am and 2 pm that I’m aware of Any advice would be greatly appreciated Thanks
3 REPLIES 3
Pagecrawler
Thank you I’ll take a look at those after work when I have more time to take it in 🙂
Mooly01
Contributor
The issue appears to be getting resolved. All in the AV forums thread.
