profile.country.en_GB.title
stevengrant
internet
when using the internet threw my google tv box chromo keeps cutting it off but never used to. why
2 REPLIES 2
gofrost
When your'e browsing using chrome the internet connection keeps being lost ? Try these steps
Reset router
Go into settings on google tv
Go to Network
Wi-Fi should show as being connected to your router (if not make sure box is checked)
Check status
If nothing shows go Add Wi-Fi network and input network key in again under security you have 3 options choose the correct one, your router should have these details.
Also if you're using a wireless connection try a wired one to see if problem occur's
Reset google tv and restart process you originally did to connect internet.
Check for updates for router,google tv and any box you may have attached to google tv.
I'havn't put these steps in any order
profile.country.nl_NL.title
breedBenR
If you are in area with many wifi networks (neighbour apartments etc.):
switch the channel of your router.
If you have the possibility to do a wired connection: do so.
If you own a router that is getting old (older than 5 years, wifi-g only) - consider to upgrade to a newer one that speaks the faster wifi-n. If the router is also your cable/adsl modem and connects you to the internet: contact your provider
