HT-ZF9 turning on TV when casting music from my phone
MartinH
Hi all, I've had my HT-ZF9 for over 2 years now and have always enjoyed the ability to cast music from my phone (typically DAB radio stations), to the soundbar.
My HT-ZF9 is connected to a Samsung TV via HDMI & whenever I cast music from my phone, it has always been just the soundbar that turns on. That was until yesterday.
I've purchased a new set of Sony WH-1000XM5 headphones & went in to the Bluetooth settings on the soundbar to pair them, which is fine. However, I must have accidentally changed some other setting, as now, when I cast music from my phone to the HT-ZF9, in addition to the soundbar turning on, the TV does too.
I've looked back through the settings but can't seem to figure out what I've changed.
I want to go back to how I had this set up, as in no TV turning on when I simply cast music from my phone.
Any ideas how to correct this?
TIA for any responses 👍
Marino.Manolo
If your TV didn't turn on when you turned on the Soundbar, then you may have turned on Control for HDMI (BRAVIA Sync in Sonys).
5 REPLIES 5
Marino.Manolo
MartinH
Will give this a go. Thanks
MartinH
Thank you for your advice. You were 100% correct & this has solved the issue.
Marino.Manolo
I'm very happy to hear that, have a good day and happy new Year...
MartinH
Happy New Year to you too!
