HT xf9000 remote code for xbox
Diggedydawg
Does anyone know how to get the Xbox one to control this soundbar?  I've tried the guided setup and manually entering some Sony codes found on the internet but none seem to work.
I use my Xbox one as a media center so it's handy to have the Xbox control the volume.  A minor annoyance but I like being able to have my echo adjust the volume and not have to have 2 remotes.
2 REPLIES 2
Pascale_F
Moderator
Hi Diggedydawg,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Diggedydawg,
I've just had a look into the manual of the sound bar and I couldn't find any codes mentioned to be able to control the sound bar using a different remote control. I don't think it will be possible to control it as when it is possible the codes for different manufacturers are mentioned in the Manual.
Cheers,
The_Black_Rose
