ralphy224
HT-CT370 Soundbar
Is it possible for a Sky remote to be able to control the volume on a HT-GT370 soundbar
Anonymous
Hi there
Unfortunately you cannot - The Sky box would need to support HDMI-CEC functions, and it does not.  You could purchase a programmable universal remote control such as the Harmoney branded that might do it.  But unfortunately your stuck with another remote at this moment.
4 REPLIES 4
Anonymous
Hi there
ralphy224
Thank you for your kind reply. I will now try to program the Sky remote to
use it with the volume on a new Sony x85 television I have bought if I
remember how to do it.
Thanks again.
Ralph
Anonymous
Hi there
I believe the following Sky website can help or assist in the codes to using the remote to the TV (if you are not already aware).
http://help.sky.com/articles/program-your-sky-remote-to-control-your-tv
Have Fun :slight_smile:
ralphy224
Very kind of you to come back with a reply to help me to use my Sky remote
with my television. I wasn't sure what to do so you have helped me greatly.
Thanks ever so much.
Ralph
