How can an internet connection be made on KDL40EX503 using wifi card in PCMCIA slot?
profile.country.en_GB.title
geordieski
How can an internet connection be made on KDL40EX503 using wifi card in PCMCIA slot as opposed to a cable or dongle connection. We can't find any reference to using this slot on the i-manual. Thanks
Tags (2)
Catmambo
Contributor
It can't I'm afraid - have to go via Sony wifi dongle or Ethernet/homeplug configuration.
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
